Won't shift into 3rd +
bendo862
Car: 1993 infiniti q45, 1971 datstun 510 (2dr) rear-ended
I have a 1993 Q45. It's a great car, haven't had a single problem until one day the shifts seemed a little laggy, then it started shifting into 3rd a little later and a little later. now it no longers shifts into 3rd or any gear above that. I can drive in 1st and 2nd only . Any ideas as to what needs to be replaced? Car has 168,000miles on it. The transmission fluid was pretty crappy when i changed it. (probably never been changed or only changed a few times). Anyway, i am hoping someone went through this before so I know what could be the problem. Brought it to AAMCO (bastards) and they said it would be atleast 1800 just to pull the transmission out and even if i decided not to fix the problem, thats how much i would be charged. This seems outrageous. Anyone have any ideas? Located in HB california.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You get a Nissan rebuilt one from http://www.everythinginfiniti.com and replace the rear engine main seal while you are at it.
Adding an external cooler is a good idea also.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If it still shifts to 1-2 its possible maybe your shift solenoids are bad... its a $150 part... Is it worht the $150 in parts and maybe $100 in labor to replace?? thats your call, but id try that first personally
If your transmission still kind of works but doesnt show signs of complete failure its worth a shot...
RobertsnewQ
Check the fluid. if it's burnt the clutches are toast and you will need a rebuild. If you don't want to spend a lot of money just get a Japanese pullout. Some of the places will even install.
elwesso
2007 BMW M Coupe
RobertsnewQ wrote:Check the fluid. if it's burnt the clutches are toast and you will need a rebuild. If you don't want to spend a lot of money just get a Japanese pullout. Some of the places will even install.
Indeed... Youll spend less, and the warranty on the rebuilds are only a year (from the factory).. If a Jap pullout has 40k, no doubt it should go for a REAL long time......
DrewQ45
Car: 1990 Infiniti Q45
Welcome to the Bad transmission Club.... and this ain't men dressed as a women misbehavin!
Your transmission has enough miles to be considered at the end of it's useful life. Time for a replacement.
Eventually I'll have time to go pick up a Japanes take-out, for now I'm just doing my homework and driving my truck around.
A few links for your perusal...
zerothread?id=128744http://forums.nicoc ... ?id=127244
Modified by DrewQ45 at 3:07 PM 8/15/2005
elwesso
2007 BMW M Coupe
DrewQ45 wrote:Welcome to the Bad transmission Club.... and this ain't men dressed as a women misbehavin!
hes right and you should be able to get another 160k out of a jap transmission with good maintenance and cooler
redmanfx
Car: 92 Q45a
You can find a JDM(Japanese) transmission with between 30,000 and 40,000 miles on it for $400 - $700, have it shipped for $200, and installed for $800, so tell AAMCO to shove it and get on these nuts!! They will rip you off and not even install it right either. Everything is on the westcoast as far as JDM trannies so take your time and you'll find something.
Sounds like you transmission has issues. My TPS sensor just went up and it did cause some transmission issues, but you problem doesn't sound related.
I AM REDMAN
bendo862
Yeah, it was totally F'ed as far as fluid. It's leaking now too. i don't really care that much except i'm driving around my rear-ended 510.. makes me sad with no radio... trust me, speed is no replacement for a radio... well sometimes it is (ortega highway & palos verdes north)
Anyway, thanks for the help guys. I found another transmission for 500 and i can install it (well, i've done engine swaps on a couple 240sxs and my datsun, so i think i can do this.) Is there anything i need to know when swapping the new transmission in?
redmanfx
Car: 92 Q45a
Might as well purchase another transmission mount as well.
red
