won't run over 3k
MissyEl
Car: 1989 Nissan 240sx
It is a 1989 240sx. Will start and idle no problem..Give it gas and it bogs down like it is gonna stall out.. If you just lay your foot on the gas pedal, it'll go have to shift super short.. under 3k for all gears will only do like 35.. I only know bc I had to drive it home like that. Tried a ton of stuff.. new cap and rotor, my brother tries to work on it for me he has 2 240's but he is stumped. Can a girl get some help please??
s13sr20chris
what happens if you slowly apply the gas pedal. does it work ok then? im thinking maf and swirl control. those are two things that come into play around 3k.
ricebike
2002 Quest
2005 Altima
Did your brother check for trouble codes? it may confirm that the Mass Airflow Meter may be bad/ electrical connection not tight...
http://www.240sx.org/faq/index.html
Quote »ECM, reading trouble codes SOHC[/quote]Code 12 = Air flow meter circuit
causing your car togo into "limp mode"
hello, neighbor...
PS: chris can u talk to your service dept & squash the myth of the VLSD additive a few threads down? thanks bud & hope u & your son have a good holiday (mine's is having molars growing in...)
MissyEl
Nah.. once the engine hits 3k your done for..
ricebike
2002 Quest
2005 Altima
Missy, that's what "limp mode" does... limit revs to 2500-3k only... to prevent damage/ raise the driver's awareness that something's wrong
scan for trouble codes should be one of the initial things to do in this case.... of course, as well as doing a visual on what chris said.
did your bro verify the trouble codes???
DrewQ45
Car: 1990 Infiniti Q45
Sounds like you need a new distributor. Had similar issue with my Q45 and it turned out to be the TPS..aka Throttle Position Sensor
the tps is not ever refered to as distributor.
yellow_jacket
Car: 95 240sx
DrewQ45 wrote:Sounds like you need a new distributor. Had similar issue with my Q45 and it turned out to be the TPS..aka Throttle Position Sensor, aka Distributor.
The TPS is NOT the distributor, nor referred to as the distributor!
The ecu should be throwing some codes, if you could post them it would be very helpful. As previously stated, this is generally a maf problem on these cars.
KAcoupe
hey check by our exhaust manifold there is plug around there....or a wire with a plug make sure that is plugged in i had the same prob...well almost the same but that came un hooked and i hooked it back up and it was fine...
s13sr20chris
thanks bro, you too.
