goyal99 »
https://forums.nicoclub.com/goyal99-u132450.html
Mon Jun 22, 2009 2:28 pm
Thanks for your suggestions....
a) there are NO ECU codes stored....I got a 55 (No malfunction code).
b) I just finished checking the resistance values for the Throttle Sensor (as per FSM EC-181) and they appear to be within specs:
- completely released reading of 1.33 KOhms ( FSM says approximately 1K Ohms) - partialy released reading of 4.6 KOhms (FSM says between 1- 9 KOhms)
- Fully depressed reading of 9.25 KOhms (FSM says approx 9 KOhms)
So if I'm reading those resistance values correctly for my Throttle Sensor then it appears to be within specs.....I cleaned the contacts and connectors well and put dielectric grease.
So what else to check?? any ideas ?? still the engine will not rev passed 2,100 RPM even with throttle fully depressed.
Modified by goyal99 at 5:32 AM 6/24/2009
