freeandam »
https://forums.nicoclub.com/freeandam-u223547.html
Mon Aug 05, 2013 9:25 am
I have a 1990 240sx SE (5 spd) and all of a sudden without rhyme or reason it won't rev over 2500rpms. It sounds like its bouncing off the rev limiter at 2500 rather than keep going. It wouldn't idle either but I fixed that (bottom bolt on TPS broke off allowing TPS to swivel.) I have already changed the M.A.F sensor, spark plugs, Distributor cap and rotor, and fuel filter (all of which badly needed to be changed.) I took off the IAC sensor and cleaned it with carburetor cleaner and I also took the front O2 sensor out to see if the problem was my CAT (it still didnt run right so thats not it.) Myself and a mechanic checked for a Vacuum leak but couldnt find one. I'm really scratching my head on this one and have no clue what could be causing the problem.
