won't pass smog help?
cal-240sx
my 93 240sx, it won't pass smog because it burning rich and it smell gas...so help someone?????please....
silpena
Car: Nis1993 san 240sx super hicas(wrecked)
soon to come to s-chasis
umm we need a little more info man like year, engine, miles, history etc. It could be a be timing or something a little as a simple tune up. Have you tried replacing spark plugs, wires, cap/rotor/ fuel filter/ or even change ur air filter? I would do those first then go back.
modulation
Replace the o2 sensor, spark plugs, and wires.
r3v_v3ng3
Car: 91 fastback ka-t
post up your test results
Cone Junky
Car: S13 fastback
BMW e46 328i
Some actual test numbers would clarify a bunch
But a common failure on these cars causing it to go way rich is broken injectors and faulty ground at the MAF.
Corers
modulation wrote:Replace the o2 sensor, spark plugs, and wires.
+1
cal-240sx
yeah i took it to the shop and they told me it was the cooling temperture sensor,02 sensor and the cat-converter. i replace all that and also all the sparkplug and wire and rotor... all that but my car still dont pass smog because it burn rich...
r3v_v3ng3
cal-240sx wrote:yeah i took it to the shop and they told me it was the cooling temperture sensor,02 sensor and the cat-converter. i replace all that and also all the sparkplug and wire and rotor... all that but my car still dont pass smog because it burn rich...
again post up your results....
also was your vehicle "test only" directed?
cal-240sx
Cone Junky
Car: S13 fastback
BMW e46 328i
It would have been much better to pay someone to diagnose it properly than throw all those parts at it.
Take it to someone who knows these cars. Obviously your current shop is just guessing
cal-240sx
the shop that i went to, they did diagnose it, thats why they told me to replace all those part but i guess still not passing, i might take it to different shop this time, let see what happen.....
r3v_v3ng3
check your ignition system, maf, and your fuel delivery
before you check the above do a compression test first and make sure the engine is in good condition.
your cat will get bad soon because the rich mixture will f*** up a cat.
is the vehicle due for a smog and was it regular smog or test only directed?
kineone2010
Car: 1998 240SX
Were in So-cal are you lacated? If anywhere near Yorba Linda I know a shop that you can take it too, drop it off and pick it up in a in a day or two and have it passed with out all the hassles of replaced parts., just a small fee. Worked there for 6 years, whole time driving a 91 s13 coupe that should never passed smog......LOL
