rogoman »
https://forums.nicoclub.com/rogoman-u37451.html
Wed Jul 12, 2006 3:55 pm
Are you getting the grinding during shifting of gears; if so, here are some possibilities:1 - the clutch pedal free play may be incorrect.2 - hydraulic fluid may be very low and/or air may be in the system.3 - the transmission may be low on oil.4 - the transmission synchros may be worn.
The high idle may be due to a TPS problem. Check the TPS harness connector pins for any oxidation.
