won't go into any gear
b0rdin4life
Car: 95 240sx
At random times while driving or sitting still, when I push the clutch to the floor I can't shift into any gear and it's like the clutch pedal stays close to the floor when I take my foot off it. If I reach down and pull the pedal back up away from the floor, it usually will go into gear fine. This doesn't occur everytime but it is starting to happen more often. Any ideas or help would be appreciated. Thanks.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
check your clutch master cylinder if you still have any fluid. it seems you are losing clutch fluid.
Blown240sx
Car: 1996 240sx
Bt its the slave cylinder going out. Ive gone through 3 of them.
S13FASTBACKSR
Car: '92 Fastback SR powered
if your clutch pedal is staying pressed downwards then it sounds like you need to bleed your clutch system..check to see if you have fluid first..if you dont then your clutch mc and sc are probably leaking...if your getting leakage from one then replace it and bleed your system obviously..if they are not leaking then just bleed your system...usually when your slave cylinder or master cylinder go bad the clutch pedal works fine but its hard to put the shifter into gear
