I had almost same problem on my 91. I posted a posted a message a few months ago with almost the same subject
. It would vary between 4750-5500, shake violently, and produce almost no power. It happened in every gear as well as neutral. My problem was a bad 5th gear sensor. It made my ecu think I was in 5th all the time, and apply the limiter when I hit 5500.
Quote »It feels like a limiter but if I push the clutch in, I am able to rev it past the 5000rpms but just not when under load.[/quote]
Are you leaving it gear or pulling it out when you hit the clutch? If you can get under the car I would recommend that you check the 5th sensor, since that is the onlything I know of that will trigger the limiting at 5500. There should be continuity in the switch when in 5th and an open circuit when in anything besides 5th.
