Won't crank now
Zouka240sx
Car: 1991 Nissan 240sx KA24DE
All I hear is a click no matter how many times I turn the switch. I've had two different opinions of it being the starter or the solenoid, but I can't tell what the problem is.
Firewind
Car: 240SX
Why do you doubt is the starter or starter solenoid? I'd make sure it's not just a dead battery first, try jump starting the car, or putting a battery charger on the battery and then see if it cranks.
If it just clicks like that it's a high chance of it being the starter itself. I would take it off and take it into shop to have it tested. I know autozone will test them, or at least they did 2 years ago.
Zouka240sx
Yeah, they still do and I do believe it is the starter.
Vandel1
Car: 1995 Infiniti J30
Same problem. But my starter is good. So I think it's a solenoid, but I can't locate it. '95 J30.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Vandel1 wrote:
Thu Apr 21, 2022 4:51 pm
1993-1996 Infiniti J30 2379630P01 Valve Assembly-SOLENOID
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
On a VG30 the solenoid is part of the starter, it's an assembly. Someone may correct me, but I seem to recall the solenoid terminal has a wire, so it can't be tripped with a screwdriver to test it. However, you can trip the battery terminal to the motor terminal to see if the motor spins. If it does and you're getting a hard click from the solenoid, then either the solenoid ring contact is bad or your engine is seized and preventing the starter from turning. If it's the ring contact or the motor isn't spinning, either way, you replace or rebuild the starter. If you do know for sure the starter is good and the engine isn't seized, then you have a problem upstream like a bad Starter Relay, Ignition Switch, or a bad starter cable.
