Won't crank after new Spark Plugs.
Katapl
Car: 91' R32 Sedan
I repaired a broken cold pipe (which even broken it started fine. it just idled like crap). I also decided to replace the plugs. I pulled the coilpacks and installed spark plugs which were exactly identical to the ones currently in the engine. I put everything back together, and the car wouldn't even crank.
I then decided to pop the clutch, and we got it running, but it was so bad I shut it down immediately. It was like it was misfiring or something, and it was shaking terribly. I tore it apart again, and I believe one of the coilpacks wasn't making contact with the plug, so I had someone push down on all the coilpacks to make sure there was contact, but it still wouldn't crank.
Someone said they heard a "click" coming from a fusebox in the engine bay. The box with that M&P/Clutch fuse or whatever it is on the drivers side. I don't know how that could have burned a fuse though. The car was sitting on jackstands while the I/C was repaired and new plugs were put on.
I'm getting heated about this, and anyones input is definitely welcome.
p.s. The engine is a CA18DET, and I already posted in that forum. I'm just posted it here for better coverage, too.
xekushnr
Car: '90 Nissan 240SX Hatch
Make sure all the plugs are firing first. It sounds like its definitely got something to do with your ignition system. Swap the coilpacks out with a buddies and see what happens.
Katapl
Car: 91' R32 Sedan
oh, and I just decided to try and see if it was the clutch switch, and it wasn't. though, I did notice a 'click' coming from the interior fusebox on the drivers side.
and i don't know of anyone around here with coilpacks for this engine.
Katapl
Car: 91' R32 Sedan
oh, and like I said... the car can be push-started. it ran like crap and seemed like it had a terrible miss, but it did run. i don't know why it can't be cranked to start, though.
that's my issue here.
xekushnr
So it wont even crank? Is that click just a single click or does it repeat?
Katapl
Car: 91' R32 Sedan
It only clicks. You turn the key to start, and it just makes 1 clicking noise. It only clicks once, and that's every single time you turn the key to the start position. I have power to everything in my interior. Lights are on and the gauges are lit.
xekushnr
Try jumping the connection at the starter solenoid and see if direct power to the starter will make it turn.
Katapl
Car: 91' R32 Sedan
I figured it may be a starter problem anyway. I just can't imagine how it worked so good until I did such minor work on it.
I'll try that tomorrow and even try taking a rubber mallet to it.
