wobley LE
jdmser
Car: duh
Yeah, I know the SE was the one to get, but I got my 96 LE for less than most of you paid for your s13's. Anyway, I had a SE-R before my s14. It had WeaponR coilovers and kyb g2s. It drove like it was on rail. Im tring to get the same thing out of the s14. As it sits right now its got eibach sportlines, nismo subframe bushings, and no rear sway bar. Its on stock wheels with crap tires. Ive got some fn01rcs w/ ventus k104 tires coming Thursday. The front end feals ok for bad tires, but the back end wobles alot. Is a swaybar going to clear that up. If so how the Whiteline, Id like to get a matching set because I heard it would clear the rb20det oil pan.Thanks for any suggestions.
aither
Car: Rock Climbing
For an S13 I know, using the RB's x-member, the RB20 has no issues with the stock anti-roll bar. You could try using the white line rear bar for a little bit, before upgrading the front.
