with sr20 turbo set up on ka24de what ecu is most commonly used.
dezi
Car: 1992 nissan 240sx
Tulsa_S-13
Car: 1991 SR 240sx
I'm guessing your talking about the T-25 turbo used in the SR. The KA24DE would require the KA ecu. If you plan on running higher boost, a JWT tuned ECU would be the best route.
dezi
so with stock boost you can keep the same ecu thats already in my 1992 240 using the t-25
get_up_mark
Car: 98 240sx se
yes you would your stock ecu unless you replace it with a tuned ecu like mentioned above or a haltach or ems standalone but those are not nessasary for stock sr boost. a piggy back system would be best to control the extra fuel from your sr injectors (that i am guessing you will be using). a piggy back gets wired into ur exhisting ecu and alters impulses to the fuel system adding and subtracting; witch ever is desired for your tune. hope that helps
dezi
thank you im not sure what to do but im sure ill figure it out
uncle_louie83
Car: 1993 Nissan 240sx Coupe
for 200 or less you can buy a used apexi safc to control those sr injectors....or for less than 500 you can get a really nice brand new greddy emanage system. its a piggyback BUT you can have some serious control over your setup. its not wise to prolly run over 400hp with a piggy back but im sure you looking to just be boosted so high hp here prolly isnt the key...so an safc will do you fine to start with...i picked mine up locally used for 160.
lewis
Nismo_Freak
Car: 89 Nissan 240SX
Better intercool that setup.
hysteria
Car: s13 kat, sv650s, and other projects
read more around the forum.... read all of the stickies at the top of the kat forum, especially the "Great Info Here, Please Read First!!!" then use the search button for finding answers to questions and when you can't come up with anything then just ask a question.
WDRacing
I'd just use the L28 with a stroker kit, makes it a 3.1, then add boost and you'll have a screamer. Or maybe the RB30...
hysteria
