wish list
sleepyzzz
Car: 2001 Frontier XE King Cab
2000 Maxima SE
2002 Sentra SE R
1967 Datsun 1600 CA18 engine swap with 4 link Mazda rear end LSD and 4.11 gears
1969 Datsun 2000
1974 Datsun 260Z 2+2
wish i had a sticky to go to for the most concise, and reliable info on purchasing and rebuilding a CA18DET engine. my recent purchase of a 67 Datsun 1600 roadster with CA18 engine has me wishing for turbo power. the car is set up with a Mazda LSD 4.11 gears, disc brakes, and coil overs front and back.
and the second pic is my 69 2000 roadster so it won't be jealous of the 67
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
frsport.com
enjukuracing.com
I pretty much built my whole CA from their site. I think I might have gotten a few odds and ends from Enjuku
CaDet s13
Car: S13 240sx
Powered by Ca18Det
^what he said. They are both extremely helpful sites with just about anything you will need.
sleepyzzz
2000 Maxima SE
2002 Sentra SE R
1969 Datsun 2000
thanks guys. now do you have a good source for the engine???????????
CaDet s13
Car: S13 240sx
Powered by Ca18Det
Well unfortunately i dont know of a safe place to buy a motorset from since my motor was in the car when i bought it. But there is a link in these forums somewhere i think its there forum sponsors. And im positve they would only put reputable places in that list. So thats where i would start. Also check the review forum for info on some places. Idk where you are located but i have heard about jdm of miami a few times.
beans33
Car: 1993 ca18det 240sx
Contact Dee, (boostboy) he might have a few laying around. if not he can direct you in the right direction.
s13drifter88
When you do your swap, get a harness from wiring specialties. They come wired for an s13 and even though thats not your application the factory one are usually pretty rough from age and having a new OE harness will make your life much simpler. FRSport will be a good place to get parts from. For rebuild Id get an OE gasket set and bearings/rings from then for a start. If youre looking for fun power Id consider a set of 550's, an S15 28 turbo with a z32 maf and nistune. you can also get your harness pre-wired for that maf if youd like, save you a little wiring under the hood later on. That combo should net you near or at 300hp which in that little car would be awesome and all pretty cheap to do as well
