Alrighty this is the run down! Eagle Rods must be modified (-$100 if you want your machine shop to modify the connecting rods)
8.3:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD 6
94mm Wiseco Pistons + modified H-beam Eagle Rods & ACL Rod Bearings = $1850.00 +shipping/paypal fees
8.9:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD 10
93mm, 93.5mm, 94mm Diamond Pistons + modified H-beam Eagle Rods & ACL Rod Bearings=
$1950.00 +shipping/paypal fees
9.3:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD 6
93mm, 93.5mm, 94mm Diamond Pistons used with OEM rods=
$900.00 +shipping/paypal fees
9.4:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD 6
10.5:1 CR =MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD! 1.7
10.9:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD! 5
93mm Diamond Pistons + modified H-beam Eagle Rods & ACL Rod Bearings= $1950.00 +shipping/paypal fees
93mm Diamond Pistons used with OEM rods= $900.00 +shipping/paypal fees
11.5:1 CR = MUST CONSULT YOUR ENGINE BUILDER TO MAKE SURE THESE WILL WORK FOR YOUR BUILD! 8
Please note prices all prices are a rough estimate! Let me know what bore size, compression ratio you are looking for and I will give you an accurate price. Best way to contact me is at
[email protected]!
