numbnuts240 wrote:... they're for laying frame, throwing off suspension geometry, tucking tires, and impressing other guys with how stupidly low they can go
Dattebayo wrote:... Coilovers are gonna ruin your car for DDing, and will make a bunch of stuff come loose in the interior. Those options would work well for both track and around town.
Your statements seem to be one sided and opinionated. Nothing wrong with that; but I'd like to add my thoughts and experiences too for the sake of bersh240, and I do apologize for taking it a bit off topic from his original intent.
I've never had a good set of coilovers 'ruin' my car nor anything come loose, especially in the interior because of them. And I've had many with all the street and track vehicles I've had in the past 26 years. There's so many variables in the choices of brand, quality, ride height, spring rates, dampening and rebound adjustments, weight, etc. so as to say they are for track only is simply not true. Street vehicles are generally designed to be built at a minimum cost, and suited for an "average driver". As an enthusiast though, I want immediate response, reduced body roll, increased stability, etc. The fact that I can custom adjust my settings from street to track is a big plus too! Also, most if not every coilover is overall smaller in diameter, so fitting your wide(r) rims and tires works much better than with the larger stock coils and spring seats. And the look that comes with those characteristics also gives a lower, more muscular and more athletic stance. Nothing wrong with that from a hot-rodding/tuner perspective either. You just have to set it up right.
