Wiring VH45 into R32... and beyond lost.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
funnygas
Car: 1991 Skyline GTS-t 4 Door
- VH45DE swap (in progress)
1995 Subaru Impreza WRX STi Type RA
OK. So. I am lost beyond belief.
I have a 1991 QX4 VH45 with harness and ECU
going into a 1991 R32 Skyline.
I have a feeling the QX4 and Q45 harnesses are different. I have some info on the R32. I have the pinouts of the 3 plugs under the dash by the ECU, I have the Engine manual for the R32, as well as the R32 ECU pinout, plus the info from v8nissans.com
I have no idea where to begin. I was trying to mesh together the s13 wiring diagram available here, with a s13-rb20 wiring guide, but am lost there as well.
Any help anyone could give would be awesome.. I want to get this thing running!
funnygas
info I have
http://24.67.163.90/r32files/
RB20 Dash Plug’s By The ECU Pinout:
Pin# - Wire Color – Description
PLUG1:
21 – Yellow/Green Stripe, Silver Dot - Receive (Control unit data input)
22 – Yellow/Silver Dot - Transmit (Data sent from Control Unit)
31 – Yellow/Red Stripe, Silver Dot - Clock(Sync Signal)
47 – Light Green/Red Stripe, Silver Dot – Check(Diagnoisos Activation)
47 – Yellow/Purple Stripe, Silver Dot – Throttle Sensor PWR Supply
Black/Silver Dot – Ground
Black/Yellow Stripe – Ground
Blue/Silver Dot -
PLUG2:
7 – Yellow/Red Stripe, Silver Dot – Tacometer Speed Signal
8 – Black/Yellow Stripe, Silver Dot –
18 – Black/Pink Stripe, Silver Dot – Fuel Pump Relay
32 – Orange/Black Stripe, Silver Dot – Mointor and Check lamp(Red)
Light Green/Silver Dot –
Blue/Black Stripe, Silver Dot – Coolant Temp Sensor(Single Prong at the front)
Green/Red Stripe, Silver Dot – Wiper Motor
Green/Black Stripe, Silver Dot – Wiper Motor
PLUG3:
104 – Green/Silver Stripe – Fuel Pump Terminal Voltage Control Output(FPCM1)
Orange/Silver Dot – Wiper Motor
Green/Silver Dot – Wiper Motor
...and lastly...
the circled plug here. It is part of the engine harness. From what I can tell it goes to the washer fluid pump, headlights, signals, and to the fuse panel under the hood etc, so I would think I need to keep it wired up...
cambo32
Car: 93 R32 RB25 hks2530
hey man this is a diagram from the 94 fsm. q45.
if u dont have a digital multimeter get one! make sure it has the continutity eg bell function so u can trace wires figure out whats what.
so from looking at this diagram... canister control valve, egrc solinoid vale, aac valve, vct solinoids and 02 sensores all need a 12v feed from the ignition switch in on position. (these can be parralleled up from one feed...get that meter out and find it.)
Pins 58,49,59,109,16,45,43, 18 are all 12v volt feeds and can be traced on the top left corner of diagram to c where they come from. then pretty much sort the fuel pump relay out and feed for the injectors, just study the diagram and follow the paths for each thing. make sure u know how a relay works and what side is the contact and whats side is the coil. pretty much all the other crap is powered by the ecu once u got the feeds sorted.
most of the wires u need are found on that plug that u circled in pic ie fuel pump ect. Where the feeds are parralleled up in diagram this is usually in the harness so may help to untape the whole thing if u get lost.
how the do i upload the pic i i cant figure this out
cambo32
send me ur email and ill send it that way cant figure this s*** out
funnygas
cambo32
email sent dude if the attachment didnt work u can find the diagrams u need in the 94 q45 fsm on this site, ec section page 10 and 211 for the ecu pin locations.
Return to “VH45DE / VK45DE / VK56DE Forum”
