Wiring up a new front end (R32)
nab911
Car: 93 Nissan 240SX SE
I got an r32 front and i got everything fitted and the headlights wire but i still have some problems. I can wire the fog lights, that wont be hard. But the turn signals are a different story. The r32 turn signals are just 2 wires, power and ground to the bulb. The s13 has 3 wire turn signals. 1 ground that is the bulb housing and 2 that connect to the bottom of the bulb. How can i wire the 3 up the 2 and get it to work? I could have just used the s13 bulbs and housing in the 32 turn signal assembly but i had already cut the wires too close to use so i have to figure something else out. Any ideas?
intrexin
Car: 91 240sx(rb20det)
One of those wires is a running light, ie says on all the time. How did you mount all the body panels or did you just mold them in?
nab911
It was a task. The bumper mounted perfectly, The hood mounted right up too. The fenders just take some work. Maybe a hammer, a grinder, a drill and some screws but we got it pretty good. Go to the convertible section and ill post up some pics tonight because i have a thread in there.
As for the wires...I tried different combinations. the power and ground hooked up left the signals on constantly, the switched wire and the ground didnt do anything. ?? Im not sure how the wires work now which is why I NEED HELP!
