Wiring up a knock sensor need help
onevia1800cc
Car: 1989 240sx ps13
i feel your angst. my ca drove fine for like 2-3 weeks then suddenly POW now i have this stupid sputtering problem.got 4 coils from float didn't change, got two ignitors from a q45 no change, got a fmic to get rid of my crap *** custom setup, no change this is driving me crazy too man the worst part is it could be anything
slownslurious
Yeah, but mine's throwing the knock sensor code. And the symptoms of knock sensor are running rich as hell (check), pulling timing (check) and problems go away above 3500 rpm (check).So I'm pretty sure thats what it is, but they are too expensive new....
fraz
Car: rb30det gts4
vh45 g130
The wire that runs from your knock sensor to the ecu must be shielded and ONE end of the shield has to be grounded. Otherwise there will be interference as it runs next to a few wires (injectors) that have changing currents.
It seems strange that the resistor trick does not work. I have done it before on a fwd and it worked. I will look into it this week
edit, just talked to my mate that has done it, Its a 1M ohm resistor that you need to bypass the knock sensor on the ca18det and vg30dettSorry to all the guys that fitted a 10k ohm resistor and have had problems
Modified by fraz at 11:59 PM 8/7/2005
onevia1800cc
ahhh 1m???
onevia1800cc
UPDATE
thank you frazthe 1 meg resistor does work!!!pin 23 to ground i hooked it up and no codes all CLEAR!!
slownslurious
DAMN I WASTED $.067 ON A PACK OF 10,000 OHM RESISTORS FOR NOTHING!!!lol damn I need to get a 1m at rat shack tomorrow, mine was pulling timing like ***** last night.
vq30det the sr killer
Car: 240sx z31 f250
any know if a you can wire in a ka knock sencer to a ca ?
mod_mastaz
Holy thread revive.
Use the CA18DE Pulsar one. It works. The KA one is a two wire I believe. The VG30DETT one is the same too I think, but you can still get the CA18DE so just buy the CA18DE one from the dealer or the autoparts store.
float_6969
Yea for searching for your answers! Keep up the good work!
As modmaster said, you can get a knock sensor from the parts store (if yours is bad). What everyone is talking about is the fact that when you do the swap, you have to run a wire straight from the sensor to the ECU.
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Holy thread revive Batman! After I was searching for the correct part for the Knock sensor I stumbled on this and I figured as a temp fix until I can get the new knock sensor I wanted to try this out. Anyone confirm it Actually works???? I went out and got my 1M resistors lol! Ready to hook it up to pin 23 and ground out the other side and see what happens I guess :ohno:
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Well made my little 1M resistor wire to connect to the ECU pin # 23 Hooked it up and for now no more stumble bumble :gapteeth: We'll see through the week if it lasts :yesnod And I will post to let peeps know for sure if it works!
