Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Tue Aug 28, 2007 9:07 pm
1991 240sx Hatchback ( Originally 5 spd )RB25DET S1 ( could have possibly been automatic motorset; transmission and motor came apart ) RB20DET Transmission
Got a question, I took apart my engine harness, im re-doing everything, Wiring specialists did it, they left pins ---
32 out which is - engine warning lamp
38 - TPS opening signal [ whats weird about this one, is that it comes out as a red wire with yellow stripe, and then goes to one of those brass nissan crimps, which then it spreads into a purple wire, and two red with yellow stripes - The Tps sensor i have has two 3 pin plugs on it, one goes directly into the TPS, and one goes out to a 1 or 2 inch subharness. Im starting to think the motor set i had was automatic because of that plug, and all of the automatic pins were in the ECU, which i de-pinned.
21(RX) Receive (C/U)22(TX) Transmit ( Data to C/U)47(CHK) Check ( Diagnosis )
I was also wondering what wire out of 47 or 32 do i need to wire up to check codes?
And which of these for the factory Consult port.
