wiring tach and air fuel ratio gauges on rb20det help..
rbpwr240
Car: 240sx
I need to know where to wire the tach and air fuel ratio gauge to on my rb20det. any body help?
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
Tach goes to tach signal behind teh gauge cluster and the a/f gauges goes to the o2 sensor wire at the computer. Dunno on a rb20 but on a rb25 which may or may not be the same the tach is pin 7 and the o2 is pin 29. Might be the same.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
rbpwr240 wrote:I need to know where to wire the tach and air fuel ratio gauge to on my rb20det. any body help?
look on rb20det.com for the ecu pin out. it will tell you what wire is tach and 02 signal. If you bought one of those Autocrapper disco light a/f gauge save yourself some time and money and buy a good wideband setup. unless you just want that gauge for the flashing lights.
Nameless EJ6
Car: What the **** do you think.
Those are as good as garbage.
