This Wiring Specialties Engine Harness COMBO includes the ENGINE and TRANSMISSION harnesses for the S13 SR20DET installed in a S14 240sx. Replace both harnesses with brand new ones and save time and money!
Get FREE shipping when ordering both harnesses together. Includes Canada Special Price - $400 shipped (Regular price $410+ shipping).
Contact: Yury - [email protected] or call 508-274-0464
Engine: S13 SR20DET
- Any Redtop from 1990-1993.5 Silvia or 180sx - Any Blacktop from 1994-1996 180sx - Supports ECU - 62, 63, E5, E4 - For ECU J4 (Type-X III) - needs to be specified when ordering
Chassis: S14 240SX
- Non ABS 240sx manufactured in 1995-1998 - ABS models need to have ABS wiring installed - select the ABS option when ordering to have ABS installed
Pre-Made Harnesses Feature:
- Brand new wiring and connectors - Installs in 15 minutes - Improved grounding routing by addition of internal cross-grounding - OEM connector specs (no cheap aftermarket connectors that fall apart) - Designed for a factory-like installation and fit and finish for the S14 240sx - Retains Cruise Control and all gauge functions - Works with the Greddy/Freddy intake manifolds - All A/C, Temp override, Auto On/Off functions properly - OEM wiring connections and 'T' junctions. No soldered connections at all - Fully tested after production for an easy plug-and-play replacement - Replaces the OEM engine harness entirely - Supports both S13 and S14 Speed Sensors - Harness supports Auto and 5-speed cars - Will improve engine performance through better grounding and power wiring - Turn Key ENGINE START Guarantee - Tech support for our customers 7 days a week.
Order WS Harness Combo here
