There is a bit of work envilving getting the head installed on the RB30 block. With additional oil drains, VTC feed, additional timing belt pulley and many little misc machining need - it is a bit of a stretch for a plug and play install.
The water pump needs to be properly seated and you have to weld on a bit of material to raise the block...
If you need a list of changes, i would suggest an Aussie site as it is a bit lengthy. I will confuse you more than help.
Turbo setup is also a bit of a tough choice. Clearly, if you are thinking of investing (or donating) into an RB30, you wanna make power. With an GT40R or 42R, there are clearance issues with the hood.
If you ask me, go with the RB26 and just throw a couple of turbos on the thing.
If not, i can sell you my engine
Yury
