Wiring Shift Light!!!
streetnissan240
Car: 1992 Nissan 240sx
I got a shift light and the wires are numbered 1 and 2. I am wondering which is which and where do they go. I would love to know how to install this light. asap . But i need some help!!!!
ill put pics up soon!!
Modified by streetnissan240 at 5:20 PM 4/11/2008
onosqv
Car: '92 240sx Vert
haha.
what brand, pic of the light perhaps?
It seems to reason that you would connect one of the wires (I'm guessing the black one) to ground & the other to the tach signal - check fsm/search on here if you don't know which wire that is.
From there, you should be able to adjust when the light turns on/off on the unit itself.
two40splease
Usually three wires: red-(power+) green-(tach signal) and black-(ground) look for a wire pinout of your ecu, one of those wires should be a tach signal
