Wiring S14 SR20 into S14 Problems.. No ignition Spark!
E7-S14
Car: ess 14 foo!
just as the title states.
i know wiring for the s13 motor in s14 is diffrnt or s14 sr in s13.
but i have no spark
does anyone know where i could find a wiring diagram for S14 SR into S14 chassis?
E7-S14
Car: ess 14 foo!
BUMP
I used all S14 SR Harness plugs..used all 3 plugs that go into the car under the dash. did cut anyof them
just extended the O2 sensor plug and MAF plug.thats it.. she turns over but NO SPARK!
im in need of a wiring diagram for S14 SR to S14 chassis
E7-S14
Car: ess 14 foo!
Bump.
Need Wiring Diagram for S14 SR20(DE) into S14 Chassis.
i found out i need to repin This
but cannot find a diagram anywhere!
E7-S14
Car: ess 14 foo!
come on.someone ..anyone?
i knows someone has done this swap before!
balmjohn
Car: 1995 240SX SE
I recently did this swap too, but I had phase2 do the wiring.
shift_SRDETuser
Car: 1996 Nissan 240SX SE
balmjohn wrote:I recently did this swap too, but I had phase2 do the wiring.
yeah dude -- if you feel like finding out were each wire goes to and looking up the specific component it powers then trying to figure out were that wire goes into the harness at. Forget about it and just send the wiring out to have it done. You will not be able to find an actual diagram for all the wires. The jdm manuals just have all the components broken down and it is a HEADACHE to figure out....
goodluck...
E7-S14
Car: ess 14 foo!
that may be the last resort
this is where im at now
i have the Pinouts for the SR20DET interior plug and the 1995 KA24DE plug
KA interior Plug
SR interior Plug
my question is can you help me with what goes where?
nzmoman
Car: 240sx 2 of em' and always lookin for more
im assuming you are looking to modify the one on the engine harness...
I will try to get a pick of mine and post it up tonight. Hopefully that will help.
Based on the two layouts you have there it seems like you just need to pick on of them and re-pin to match the other, but i will try to get pics up tonight.
E7-S14
Car: ess 14 foo!
unfortunately no one knows how to wire a SR20DE into a dam S14
so im at the point where i just wanna sell it and buy a dam KA
Phase2 No longer offers their wiring specialty
so im pretty much fvcked
E7-S14
Car: ess 14 foo!
well.
it seems im keeping the N/A SR.
Im gonna bite my pride and let the pros handle this
im sending my harness off to Wiring Specialties a nico sponsor.
knowing that their a nico sponsor makes me feel a little more safe about sending such precious pieces of wire across the country
i guess my only problem now will be dealing with my horrible patients..since turn around time is 4-6weeks....
fast_s13
E7-S14 wrote:unfortunately no one knows how to wire a SR20DE into a dam S14
search is your friend i have a write up on here
Taylor_Durdan
definately. a search would have either found a write up or found anyone of us that are competant enough to do it. i have probably done over 75 S14SR's into S14's!!
E7-S14
Car: ess 14 foo!
fast_s13 wrote:search is your friend i have a write up on here
Taylor_Durdan wrote:definately. a search would have either found a write up or found anyone of us that are competant enough to do it. i have probably done over 75 S14SR's into S14's!!
Write up for a S14 SR20(DE) into a S14 Chassis?Where!?
ive searched for days and came up with jack **** for the (DE) into S14
jtweezy25
Car: 96 s14
im in the same spotdo u have a diagram to repin it. if you do that would be awesome
E7-S14
Car: ess 14 foo!
eh.i don't.i gave up and let a local shop do it for me.
it was well worth saved headaches.
they wont give up the diagrams
keaning
Car: zenki s14 kouki sr20det
did you ever find out the problem, im having the same problem right now with no spark
