skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Sat Jan 14, 2006 11:11 pm
The black and pink wire just needs a good ground as far as I know, I connected to one of the black/pink on the ECU but I cant remember which. Others have said its just a ground though and can go anywhere.
And the white/purple wire, like I said in the write up there should be a wire with 0 volts in that same plug, Im not sure why it would have 1+ volts in the off position. Someone else post up and say if thats OK to connect on, because I dont know.
