TheKon »
https://forums.nicoclub.com/thekon-u56744.html
Sun Feb 18, 2007 8:52 am
I have the one piece components...I didn't want to cut a hole for the tweeter in my impala (it's my first car, I'm selling it for a maxima and 240 as soon as I get approved for financing) The ignition wire...I'm not sure what color it is in the 240SX...there should have been a install instruction sheet with the ipod adapter...hmm...the red wire with the black stripe should be the ignition wire (it'll be in your ignition harness) don't quote me on that though. An easy way to figure it out is to turn your car off and see if that wire is reading 12V if it is then its just the constant 12V and isn't switched...if it reads 12V only when the key is in the on position then it's the ignition. But actually I just looked up the install manual for the ipod adapter and its switched through the head unit...just hook it up to constant 12V...you can use the same wires your head unit is using for power.
