TWAN »
https://forums.nicoclub.com/twan-u23973.html
Thu Jan 06, 2005 5:00 am
Okay i have been done with the swap for quite a while. And I have searched numerous times and seen nothing on this. Just wanted the mystery solved for peace of mind.
My question is concerning the gauge cluster after my swap. It seems the only lights that work are my e-brake, seatbelt, and door open warning lights. Everything else never comes on, even when i turn the key to ignition on position I only get those 3.
I first thougt it was the gauge cluster because I swaped the USDM with the NISMO one. But I put the USDM one back in and i only get those 3 lights.
Now when I did the wiring under the dash for the cluster plug I remember there being like 5 or 6 left over that were listed as KA check wires. Are these the wires that get a signal for the other four warning lights? If so does anyone have the schematics on which wire conects to which wire? Reason is because there is 4 wires left over on the SR harness and 5 or 6 left over on the KA side. Like i said i have been searching and seen nothing on this, so any help would be great.
