Wiring Question - EGT, A/F Gauge
ChillyWilly3
I have a 1996 240SX SE. I have yet to receive the repair manual for it, but I figured many of you guys had installed EGT and/or A/F ratio gauges on your 240s already and would be kind enough to share your knowledge.
I just need the wire color(s) for (1) a constant 12V at ignition ON and (2) a 12V source only when the headlights are turned on and (3) the O2 sensor wire (after the O2 sensor assembly). Actual locations of theses wires under the dash would be a plus.
I just installed an Nsport Stage I and I'm not really looking forward to wasting more time doing more trial and error activities especially with the electrical system. Thanks!
ChillyWilly3
bumparooni
Queamore
Car: Cars.
look behind the radio for number 1 and 2. You'll need a battery tester to find out which one is which 02 sensor don't know.
