wiring problems
kage
Car: car
In the 89 240sx there is a clock on the dash i dont know if this is true for all years. I bought the car last week and wanted to install my pioneer deck. I wanted to hard wire the system without the sockets and when i cut off the existing sockets the clock stopped working and my stereo powe was dead. This morning i was fiddling around and while i was checking the fuses the clock came on and there was power to the stereo. at this point the stereo wiring was all grouped into the deck together, possibly joing a connection, but when i went to pull the wires out for more slack the power died on the clock. I know there was power to the stereo cause the speaker was staticy from a connection to the 12v i assume. plz help. I predict that maybe two of the wires in the mess of things should be connected in order to complete a circuit but really have no clue.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Well the clock and radio might be on the same fuse but are not on the same circuit. I would check for pinched wires behind the dash which might be causing your problem. I wouldn't be surprised if you made the problem happen by lopping off those factopry connectors. Rule number 1: never cut anything off always make a connector that works or buy one. Nissan's electrical is all over the place, you never know what systems you could be effecting by cutting something.
