i installed a new stereo for my pops in his cherokee. when u pull out the old stereo there should be a diagram on it of what each wire does. you can then carefully cut wires and connect them to the right ones on the new stereo. also double check if that diagram is the front or back(wireside) of the connector.
If u connect it wrong and short it either the Ignition Over Draw fuse or the stereos own fuse will blow... be careful.
I have heard of little adapter things that let u just plug it imbetween the stereo and the old connector but i dunno... just go slow and be patient. remember shorting is baaaaaadd!!!
