wiring problems still gtir
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Spooled_GTIRSENTRA
Car: 04 Sentra Spec V, 93 sentra with GTI-R (sr20det) swap
the swap is almost finished. still no spark. i bought a brand new coil and checked all the wires from ecu->power resistor-> resistor and condencer-> coil and there all good. the ecu is still not putting ENOUGHT power to the coil. its sending some power but no where enoght. i had 2 broken clips on the distributer cap, so i replaced that.
my MAF couldnt be messing anything up? im trying to use the stock ser (b13) MAF. i herd from somebody that, that could be the problem. if i need to swap a different one in that wouldnt be a problem. my buddy has a couple z32 maf laying around.
Thanks Tony
Spooled_GTIRSENTRA
also, what is the specs on the resistor and condencer? could my ecu be messed up? how can i check to see if my ecu is still good?
Thanks
nametakennow
Car: '06 MINI Cooper S
I'd use a Z32 MAF anyway, you're going to want the extra capacity with a GTi-R.
I don't think your ECU is the problem. However, I also don't know the resistance figures. Do you have an FSM? If not, get one from the link in my sig.
Spooled_GTIRSENTRA
yeah i have many fsm's. for the gtir and the b13.
thanks
nametakennow
If there are specs to be had, that's the only place you're going to find them is why I asked.
Spooled_GTIRSENTRA
i have the z32 but i was wondering. you dont need the JWT turned ecu to run that MAF do you. i herd that it wouldnt work on my gtir ecu.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You can run the MAF with the GTiR ECU, but you need a S AFC or emanage for it to work properly.
Spooled_GTIRSENTRA
i have a safc. sweet, thanks
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
