Wiring problems gti r swap
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Spooled_GTIRSENTRA
Car: 04 Sentra Spec V, 93 sentra with GTI-R (sr20det) swap
Im doing the Gti-r Swap in a 93 sentra ser.. the wiring has me so confused, the harness was cut before the ecu and they didnt give me the clip from the regular harness. people say that all the wire colors should match up to my stock sentra harness, but they dont. cant figure it out!! if anyone has done this swap let me know how you made this work...
also the injectors have 2 wires plus ground the stock engine only has one plus ground.. somthing isnt right, whats up with this? i have the sr20det ecu A11-000 A00 23710 54c00
Spooled_GTIRSENTRA
or does anyone have a uncut wiring harness for sale?
nametakennow
Car: '06 MINI Cooper S
The GTi-R harness is a bit of a trick to get with an SE-R harness. I'll go find the page I saw about it and email or post up later.
NAKA24DE
Umm.... you just use the SE-R harness and a JWT ECU reprogram on the SE-R ECU and your done !! Oh and swap the two outer wires on the TPS ! And get resistors for the injectors from JWT ...
nametakennow
Emailed.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
