Wiring problem: Door locks
daltonnnn
Car: 1993 Infiniti j30
Anyone have this problem that when the interior gets hot, the only door that will lock and unlock is the drivers. If you keep pressing lock and unlock, it still only locks and unlocks the drivers. WHen its cool, however, its fine.
My guess is wiring because infinitis are known for wiring problems.
Anyone have any comments, feedback, or same thing going on?
vishesh
Car: '95 Infiniti J30
never had this problem. but i could totally believe it is a wiring problem, since i have a wiring problem with my Bose HU. i think it is a cold-solder connection (i.e., when it is cold outside, my Bose HU's display doesn't work. when it is warm outside, the display works fine) sounds like the opposite is happening for you...
gr8scott72
Car: 1994 Infiniti J30t
vishesh wrote:never had this problem. but i could totally believe it is a wiring problem, since i have a wiring problem with my Bose HU. i think it is a cold-solder connection (i.e., when it is cold outside, my Bose HU's display doesn't work. when it is warm outside, the display works fine) sounds like the opposite is happening for you...
A cold-soldered connection doesn't have anything to do with the outside temperature. It simply means that the solder joint was not completely flowed to the degree it needed to be to make a good solder joint. It usually leads to the joint breaking apart or partially breaking apart down the road.
I'm not saying that you don't still have a wiring problem. I'm just saying that your definition of a cold-solder connection isn't quite right.
