wiring?need a lil bit of help!56k killer
midnightsliding
pic #1 what is thispic #2 what do i do with these?pic #3 what about the conection to the dash and instrument cluster? its two female ends, do i have to cut and splice new male fitting into it?pic#4 what is thispic#5 what is this and where do they go
iliketocrash
the first picture is the dropping resistor pack. its a necessary part to drive your injectors. the rest.. well i can't really see where they are in relation to anything else. i don't know anything about the gauge cluster because i'm just using the USDM one in my 240sx. overall i think i only have two plugs left hanging around in my engine bay and everything seems to work alright.
iliketocrash
actually i think the plug in the fourth picture might be some type of check connector. i don't believe that needs to be plugged in. someone correct me on this if i'm wrong. Is the brown plug in the second picture near the battery tray? if it is i believe you have to use the matching brown plug from your old KA harness and splice it in to your CA harness to match up with that already existing brown plug. but don't go doing anything until someone else confirms this.:D
92CA18Hatchback
Car: bASEBALL
Check out heavythrottle.com. They have a wiring guide for the sr20 which the same as the ca wiring. I used this and everything seems to be hooked up fine.
pulsar gtr
Car: NISSAN VEHICLES
Well, the first is your dropping resistor pack and it is needed, it should plug on one of the big plugs on the engine harness.
second and third pictures as they mentioned , go to heavy throttle and follow the wiring, you to cut this plug off and use the KA plug and wiring it back on.
fourth, I don't think it plugs any where, but can't see the exact location on the harness to tell you for sure.fifth one is your detonation sensor plug, it goes under the intake and plugs on the detonation sensor in the middle of the block.
Heavy throttle have a good description of the 2,3 pics.
Good luck,
PULSAR GTR
Twiztid_S13
Car: Cars, Anime, Women ;)
I used heavythrottle's faq .... worked good .. easy .. atleast i thought so
