rustbucket wrote:All I did was hook up the essentials, ignition, eccs relay, fuel pump, 3 maf wires, oil pressure, temp, tach, speedo, fuel gauge, high beam ind, turn signal ind, gauge backlights, gauge grounds and ecu grounds. Its really only 20 wires or so. I havent driven it yet, but it starts and idles fine. I used environmental splice crimps, they are alot faster and easier than soldering and still give the same quality contact.
I might have not mentioned some wires, but I think that was about it, I dunno, I wrote it down so I wouldnt have to remember it.
Whats the point of adding relays? Seems like your gonna make it more complicated than it has to be.
at first i didnt know what you was talking about when you started to mention high beam ind, turn signal ind......then i realized you was talking about the r32-33 gauge cluster, right?
if you can double check with what wires you used from the efi harness, that would be awesome. the only reason i wanted to run relays, would mainly be for the fuel pump. its nice to know that the fuel pump will be getting its dedicated 12v while under high boost.
