wiring issue
slidecrave
Car: AE86, S13 CA coupe
So on my way driving down the highway.. the ****ty *** orlando roads end up causing my front right pass-side tire to blow and it shedding up some of the wiring harness on that side. Well when i went to try to start the car it wouldnt start, and ended push starting the car and well it then drove fine no problems and i got it home and thought everything was ok. Well i go to try to start it again and it doesnt want to start, no cranking or anything. Like if the starter was unplugged but i checked that and everything is connected and it was working fine before blowing the tire.
So the question is i found some unconnected wires on the harness since it fell down when the tire blew and i had to tape it up on my fender to get it out of the way. And i'm wondering which wires down there could be causing this problem?
Nunook
I know on the driverside that thick harness goes to the fuse box in the kick panel. But the passenger side??? i dont know. good luck.
slidecrave
can anyone help me out with this
float_6969
The wire isn't disconnected going to the starter, is it?
slidecrave
no that was the first thing i checked.. i'll try to take some pics of the wires im talking about and see if thats any more helpful
