wiring injector connectors
Hank857
Car: 300 TTZX
We are in the process of R&Rg the injectors on a 91 TT. The new leads ae red and black, the oem leads are white on black and green on white I think. Does it make any difference which is wired to which as I was told one time it made no difference they will work! Stopped at dealer and they have no info on a veh 'THAT OLD' so went to a indy shop and was told that it is a true statement but they recommended black wire to the wire with black and red to the other. I cannot find a wire diagram showing the hot and ground wires and system is apart so cant turn key on without fuel splatter.
Any help appreciated.
Metacom
Car: 1994 300ZX TT
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Shouldn't matter, if both wires are different gauge, connect thicker wire to thicker wire. Just keep them all consistent.
