Wiring info needed.
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
I am trying to find out a few things wiring related on the Versa.
1. does the interment cluster use LED's for the security light that flashes in the center or is it a bulb?
2. I would also like to find the factory (I key) or remote box that sends signal to that security light.
3. The wire color to that light.
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
I can't answer your questions, but I'm curious... what is it that you're trying to do?
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
Service Manual pages BL-193 through BL-211 cover the system in some detail.
1) It's an LED.2) It comes from the BCM.3) On Combination Meter M24 positive is Green at terminal 27 and ground is Red at terminal 18.
Urq
Thanks. Kc5f....
I am hardwiring a passport 8500 radar detector and it has a button for mute I have to mount and there is a red led that I would like to incorporate with the security light in the center of the interment cluster.
I will put up a DIY if anyone is interested.
Modified by Urq at 2:29 PM 11/26/2007
kc5f
2012 Nissan Versa
2016 Nissan Juke.
Hmmm, had I only known... Well, don't get overconfident with that radar detector there in California or you might be interred with your "interment" cluster!
