MikeDombeck wrote:i just want the car re-wired, everything... it hasnt ran right since i got it, and the guy who did it twisted the wires...... it always mis-fires, and even when it was running its best, it misfired at high rpm's (7k), it is a stock motor, so that shouldnt be happening.
Do a diagnostic check on your ecu. This will tell you something about suspect wiring or components. If I was closer, I'd be happy to make your money, but try the diagnostic thing first because it may be something you can fix yourself and save some $$$s.
Dee
