Okay, I have a AE86 with a CA18DET installed. All I have is the main engine harness, no relays or anything. What is the bare minimum that the ECU needs to see to start.
My Guess is:
59 B/W: needs 12v power (ECU Power)
60 B : needs Ground (ECU Ground)
44 G/O : needs Ground (Neutral Position Switch)
43 O : needs 12v cranking (Start Signal)
I have 12v and Gound at each Coil Pack.
