Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Wed Sep 09, 2009 2:49 pm
who did the harness originally, it looks similar to how i set the ones i convert up.if it DID pass thru my hands then there wont be any plugs that need to be removed nor stray wires.you'll need to reconnect the old green relays as the skimpy thin gauge wire you're trying to pull power thru on the blue relay plugs will fry and possibly cause a fire.just play match the colour on the green plugs and you'll be fine.
