just a little back ground i picked up a 240 with a ca in a trade. So i'm starting to go though the car and figure out some things and the first major problem i've found is the wiring. Its a rats nest loose wires every where wires that lead to nothing and some just randomly cut but heres whats bothering me the most, there is 7 wires by the ecu that are not hooked to anything and I can not find where they go here are the colors-light green-2 different solid white wires-blue with white stripe-2 different Black wires-Large blue wire with red stripe
NOTESI pulled the tape back and found bother white wires are coming from two different sheilded cables
-one sheilded cable contains one unhooked white and both blacks (one black goes to the sheilding inside the cable) I think this might be the knock sensor since the knock sensor has been rewired externally from the harness.
Just to let every one know I use Blue painters tape to mark the areas on the harness that need attension lol.
