wiring help silvia turn signals?????
azwhitesil80
i have searched zilvia, here, az240, houston240, nv240 and got nowhere does anyone know were i can find a complete wiring write up on on installing silvia turn signals
Hijacker
Car: '92 240sx Convertible
'94 F-150
I know I've answered this question before in the past, but I can't seem to find it.
Just run some extension wire from your turn signal plug to the front bumper light. Then tap into the Green/black and Green/Yellow wires for the power and ground the other wire out (i usually just ground them with the front marker lights' ground, Black)
easy as pie.
If you need to look at a diagram, the factory diagram for a 240 can be found on page 35 of the EL Section of the FSM
