Wiring Help (Nav System)
NY94J30
Car: 2000 Q45 AE
I can't seem to find the instrument cluster pin out in the FSM. I am trying to find a 12v for the VSS and a reverse signal. Can someone help with a color/pin #/location of a VSS/reverse signal behind the gauge cluster, at the shifter or behind the HVAC/stereo?
Some pics:
Modified by NY94J30 at 3:37 PM 5/15/2007
pdqwrx
Car: 1989 240 SX, 2002 WRX Wagon, 2003 FORD f150 4DR
I show the VSS to be a Pink/Blue Pin#68 on ECM in passenger kick paneland reverse wire to be Blue/White in the drivers kick panel and is positive trigger. As always use at your own risk please verify with a DVM (Digital Volt Meter).
CheersScott
NY94J30
Car: 2000 Q45 AE
Thanks, Scott.
ILuvNkdChx
Car: Q45t, I30t
If you are mounting your nav. unit in your trunk, you are able to run the "reverse lights" wire to either positive terminal of your reverse lights. That will save you having to run it all the way up to your driver kick panel.
Also don't quote me on this, but I believe the VSS is a 0-3v source, not a 12v, (mine was 0-3v) please verify with volt meter. For that you DO have to run to the passenger kick panel. Good luck, I just finished mine yesterday!
Q451990
Which head unit are you using? That's a nice looking install!
Heath
NY94J30
Car: 2000 Q45 AE
ILuvNkdChx wrote:If you are mounting your nav. unit in your trunk, you are able to run the "reverse lights" wire to either positive terminal of your reverse lights. That will save you having to run it all the way up to your driver kick panel.
There isn't a separate brain on this unit, it's integrated - and I would much rather not have to run a wire from the dash back to the trunk to find a reverse wire. As for the voltage at the VSS, you're right, it is variable, I was actually referring to the reverse wire; I wasn't clear.
q451990 wrote:Which head unit are you using? That's a nice looking install!
Heath, I decided to go with the Pioneer Avic D3.
http://www.pioneerelectronics.....html
