Wiring Help in SOHC
Trppen37
Car: CA18DET
ok I figured out the wiring for the Dash Side: I do have pictures of everything but I dont know where to post them from.
Yellow / Red stripe Tachometer signal
Yellow / Green stripe Speedometer signal
Orange Ignition start
Black Ground
Blue / Green stripe AC signal
Blue / Black stripe Water temp signal
These all match.OK now on to the Engine Side. The Problem im having is the Plugs leading into the fuse box. The Colors on the SOHC is not the same as the Diagrams from HT and NissanPerformanceMAG since they all installed the engine in a Kouki. I need to know which wires on the KAE mean. The Chiltons sux0rs. I already extended the MAF. So if you can help I can probably create a Sticky on how to install the engine in a SOHC.. thanks alot
Twiztid_S13
Car: Cars, Anime, Women ;)
i did my sohc using the HT faq... all colors were there.. colors may be a lil off but it worked... also remember to hook the knock sensor up direct.. cuz the sohc models didnt have it ..
float_6969
http://www.srswap.com/faq/index.asp#harness I used that and it pretty much worked like a charm. As he said, you'll have to straight wire the knock sensor into the CA harness as the SOHC's didn't have a knock sensor and so they won't have the wiring for it.
Trppen37
Car: CA18DET
are you sure it worked like a charm?? because on the CA harness theres the IACV Wire and on my Grey Plug there is no wire in that spot.. I did although spliced the ca harness to the male connector of the KA Lower Harness in order to plug it in the Fusebox..
float_6969
The ONLY thing that I didn't do EXACTLY like that was to hook up the brown O2 to the brown in my SOHC harness as it was a switched 12V source.
WeldingHank
Car: 1989 240sx CA18DET
i just did the wiring in my SOHC. it was all there.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i did the wiring in my sohc using the HT diagram. it worked great.
- tim
Trppen37
Car: CA18DET
man im soo dumb..it worked like a charm...i was looking at the wrong set of plugs lol
r34 gtr
its okay. we all do it (i think, could just be me). hope all goes well from here.
- tim
