Wiring help - German headlights
Philipio
Car: 96 240sx, 96 Miata
As some of you know, the Zenki glass headlights don't have the same connector for the brights. Due to this fact, I haven't had working brights since I bought these headlights a long time ago. I would like them working and I'm a novice to wiring.
This is the stock connector from the harness: http://img.photobucket.com/alb...1.jpg
This is the connector on the headlights: http://img.photobucket.com/alb...8.jpg
This is the difference between the two: http://img.photobucket.com/alb...4.jpg I tried putting in a stock bright that connects directly to the harness but that was EXTREMELY ghetto looking and wasn't realistic at all, with the light hanging half way out the headlight and at a weird angle.
What are your recommendations? I don't want to just cut the wires and solder them together. I want something a little less permanent.
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
- Cut connector off headlight, replace with stock connector, solder wires Pro: not cutting the car's harness
- Cut harness connector, solder in euro connector Pro: not cutting the headlight harness.
- get euro male connector, and the stock female connector, solder these two connectors by thir pigtails, connect stock conectors, and connect euro connectors. Pro: not cutting anywires.....
Philipio
ag240 wrote:- Cut connector off headlight, replace with stock connector, solder wires Pro: not cutting the car's harness
Can't exactly cut the connector off that. If I'm wrong, please correct me.
Don't know where to get a Euro male connector
Third option is a super daisy chain, could work, again need the Euro male connector though.
