zmannz »
https://forums.nicoclub.com/zmannz-u23244.html
Wed Mar 03, 2010 12:34 pm
Ok, not to be a meanie, but i am actually just cruising through from the rb forums and I have a b series. Anyway, you should really search for more info about what you want to do if you don't know what we are all going to say to you. Search for a swap guide for the vg30 going into a vehicle similar to yours and go from there. Most likely all you will need to hook to the motor and ecu will be 12v and grounds in a few places, and as I recall the b2200 has a crappy mechanical ignition, so you would need to route these connections through some relays probably for reliability. And from there, a little creativity and custom fab will get it done.
