nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun Nov 25, 2012 9:02 am
Search is your friend, been covered many times. But, I can help.
You can use your stock N/A harness, it will work, but some connectors will be a stretch to fit, but will still fit. ConceptZperformance, Z1, specialtyZ, Bernie on TT.net all have wiring harnesses. If you do get a new harness, get the TT one, but you will not use some of the connectors and this is normal on swaps.
Stay away from a manual boost controller, they are just and could cause more issues down the road. If your going to do this project, do it right. Also search about JDM on these cars, they can be a crap shoot, some have gotten lucky others have not. This is a huge project and expect to spend 5k-10k depending on upgrades or just little things that you will need. Its not an easy task.
