Wiring Harness
ride4lame
Ok, this may sound real stupid but thought you guys could maybe save me some time. I am taking the KA wiring harness out of my car. I have it all off in the engine bay. Inside the car, is there a way to get it out without ripping the dash apart? The SR harness looks like one clip... is there a way to get this out easy? Thanks
BuudWeizErr
pull it out through the engine bay. There is some fun manuevering, but it'll come out.
ride4lame
How do i get to the clip inside the car? can i yank then it will fall into my grasp?
SET240SX
Car: fast rides
I justed swap my harness out. Was way easier than i thought.
I unconnected it from the ecu and dash plug then removed the bolts on my heater fan housing. Lifted the fan just enough to slide the plugs behind it and it popped right out into the engine bay. Not really much to it.
Before you put the sr harness in better change the plug going to the dash. If that plug needs to be changed? You dont want to be soldering upside down in that floor space.
