azncorruptedo17 »
https://forums.nicoclub.com/azncorruptedo17-u17403.html
Mon Jan 17, 2005 3:24 pm
i heard you can use the same gauge cluster, if the back (circuit board thing) is blue. i believe the blue ones came in on 1990.5 > 1993 models, and should work since the green backing came only with 1989-1990 models. (sohc)
but my question is... why do some 1990 240s have a blue backing on the cluster since the blues mostly only came in the dohc 91-93s.... weird...
if you don't know what im talkin about, ill try to clarify ^_^ but since this probably has no connection with the topic, i probably won't =X
